RE: can you run a b20 direct drive?
Generally speaking, not with much of a prop... Because the motors are so high-strung (high Kv/high RPM), the prop must remain small to keep the motor from drawing too many Amps and burning out.
As for what size prop... There are several B20s... Which one?
