shielding spark plug cap & wire
Can the Bosch metal spark plug cap be used with a spark plug cable with stranded wire core ? If use a copper sleeve over the spark plug wire and connect the sleeve to the metal spark plug cap , is it then still necessary to ground the sleeve at the ignition unit end ? Tks
