RCU Forums - View Single Post - Please help,CG location of Me-109
Old 11-02-2002 | 12:47 AM
funfly65
Default CG on ME 109
I too bought a ME 109 ARF that was already completed. But the guy I bought it from was kind enough to provide the manual as well. So - here goes from the manual.
Model Tech ME 109 .25 Size
The CG is located 2-1/2" back from the leading edge of the wing at the fuselage sides. This location is recommended for initial test flying and trimming. There is a 1/4" margin forward & aft, but it is not recommended that the CG be located any further back than 2-3/4". BALANCE THE ME-109 WITH THE FUEL TANK EMPTY.
Using a couple of pieces of masking tape or a pen, mark on each side of the TOP of the wing 2-1/2" back from the leading edge (you balance the model inverted). YOU KNOW THE REST.
I have a Saito .30 in mine with a 10x6 Master Airscrew and it flies great with the CG right where Model Tech recommends. Be careful on initial take off it will want to dip a wing if you don't let the ground speed come up, but once flying its pure fun. Mine likes to land a bit hot but nothing unmanageable. No unexpected tendencies that I've found yet.
I'm sure you'll have a blast.
