RCU Forums - View Single Post - Mounting Rimfire on Flatana
Old 10-05-2005 | 10:02 PM
aflipz
My Feedback: (10)
Default RE: Mounting Rimfire on Flatana
this is my second rimfire, if i remember correctly the first one did not have such a large collar over the shaft, if i recall correctly instead of the collar + set screw it was secured to the can via a circlip like the ones holding the shaft in gws style gearboxes. i suppose you could remove it if you were running the motor upside down, inside the firewall with a prop adaptor. wich would explain why the mounts need to be revised.
