RE: Minimum airspeed
May I get some advice and guidance on prop sizes for a 09 Enya? The LHS doesn’t stock pusher props making a normally simple issue more difficult.
Bench running the 09 with an 8-4 prop (tractor for testing) gives only 9500 RPM, which seems way too low. I found only two makes of pusher props, Graupner and Tornado and the selection was limited. Must be looking in the wrong place.
What prop size would you suggest? Where is a good source of supply for pusher props?
Thanks.
Bill
