Sturtz:
I am getting ready to cut my cowl. How did you get the cowl over the Pitts muffler? Did you soak the cowl in warm water? My power plant is an OS .91
. Let me know your inputs. This is my first cowl I have to cut. I have some clear plastic I was going to use to outline the engine and the muffler and use it as template to cut the cowl.
Dual Elevators: What is the difference between a reversing y-harness and a regular y-harness? I am not so worried about the torque, but what if the two wheel collars fail. I am using a regular y-harness in my tiger 2 for the elevators since the dowel rod that connects the two elevators halves got fuel soaked. Bummer!!![:@]
The PCM version - is this just an upgrade version of the receiver? Great radio except for the dual elevators issue[:@]
