RE: Kit building basics? Tools, etc.
One trick I found is that CA will not stick the backing film on monokote..
I'd always build on a piece if I thought I might accidently glue something to the table.
I've even built right on the plans using the clear backing to protect it.
You won't have any around on your first build but you'll have a ton after covering a wing.
