RE: Mounting Rimfire on Flatana
Ok for the ESC motor hook up, put them into any one, if it runs backwards reverse any two wires, and if the polarity to the reciever is wrong, it just wont do anything, if its right you should hear some tone, either for programming mode or flight mode, look to the instructions for this, also if you go into the programing and set the timing where they tell you to for the outrunner motor it helps a bit.
