RE: Skymaster Hawk Once Again (at least!)
Hi,
Does anyone have knowledge of the ne "Wasp" engine. Its seems to be the same size and weight as the Wren S/Sport and lower rpm but similar fuel consumption but producing 20 lbs of thrust !
This seems to me if it works to be very worth consideration as with appx 2lbs plus more thrust but same weight this would produce a lighter loaded frame with good Power weight ratio.
However like all things in life, simply does it do what it says on the tin ?
David
