RCU Forums - View Single Post - how do you fix stuff?
Old 10-07-2005 | 07:42 AM
bruce88123
Default RE: how do you fix stuff?
If you have all of the pieces or it is just cracked you can usually glue them back together. If not repairable, get new balsa sheet of proper thickness and use adjacent rib as a template for cutting new rib (or portion needed).
It's not the only way to practice but the best, because you end up with a new plane.
