RCU Forums - View Single Post - Does it cost more to by an ARF or to build from scratch
Old 10-07-2005 | 08:04 AM
D Bronk's Avatar
D Bronk
Default RE: Does it cost more to by an ARF or to build from scratch
ORIGINAL: Jim_McIntyre
As my Grandma is fond of saying "You get what you pay for".
.The other thing besides NOT being cheaper, is when you build your plane ,you can CUSTOMIZE it to your prefferances,ending up in a "ONE of a KIND" model.YOU may see other planes that look similar,built from the same kit, but there`s none, that will be identicle, in every way...I think ,that with ARFs ,the company`s looking to make a buck and they shop around to find the the "best bargain" possible for parts that are installed in the pre-built plane.I`ve seen many times, planes equipped with, not so great retracts ,for example,just to keep the ARFs price down..THINGS like that are in the builders control, if your constructing from a kit..You can shop around,for the, top of the line parts,or of a lesser quality, (up to you)for your "NEW AIRCRAFT". MY GRANDMA used to say, CHEAPER is CHEAPER,meaning costs less,but you get less....I wonder if our grandmas went to the same school,JIM[....
