RCU Forums - View Single Post - E-Flite Brushless Conversion (I did it!)
Old 10-07-2005 | 09:59 AM
bdavison
Default RE: E-Flite Brushless Conversion (I did it!)
The Blade is a PPM(FM) reciever
The 9CSuper will fly PPM, and PCM1024 recievers. You can select which right off the main menu.
It wont fly the old PCM512 recievers, but you will rarely see these. The only Futaba radio I know of that came with one was the old single stick one.
Im working on getting the set-up for the Blade programmed in mine. Once I figure it all out, Ill post it up here so everyone can use it, I dont want you guys to have to figure it out. Its complicated if your starting from scratch.
Also you get a CAMpac module with it that will hold about 6 airplanes, and the radio itself has a 12 plane internal memory. You can get more CAMPac's later that will enable you to store up to 1000 different airplanes.
