RE: E-FLIGHT BLADE CP
Ok guys,
I got tired of flying the blade around on that stock tx, I want to have some fun with this little bird, but I want adjustable pitch curves, throttle curves, revo mixing, revo mixing....DID i mention revo mixing.... etc.
So I went and bought a 9CSuper with a synth module. Im working on trying to program this thing to work with the blade.
Have any of you done this with a 9C?
Ive figured out that I have to use SR-3 swashplate mixing, and then -50% the ail Swash AFR, because e-flite reversed the ailerons....sneaky little**** , It took me about 4 hours to figure this one out. Went throught the manual about 3 times before it made sense. Had to stop at 4 hours, to recharge the TX so I could finish programming it.
Ive flown a flight on it in normal mode. Works fine, Gotta get the idle ups programmed in there now.
