RCU Forums - View Single Post - E-Flite Brushless Conversion (I did it!)
Old 10-07-2005 | 12:51 PM
  #33
bdavison
Default RE: E-Flite Brushless Conversion (I did it!)
You wont need a CAMPac for it.....The CAMpac is just for saving your setups once you enter them into the radio. If two people have 9CSupers, you can swap airplane setups by putting there campac in your radio, and copying the "plane"
What Ill probably do is once I get it all set-up, Ill post TEXT including the settings so you can just dial them into your radio.
Im going to program it for the stock 4-in-1 box, and try to match the programming exactly like how the stock transmitter works to begin with.....then start tweaking it for max performance.
So far, This is what Ive got....
Swashplate type - SR-3
Ail Swash AFR = -50%
Norm Pit-Crv - 0,13.5,15.0,20.0,37.0
At 37.5 you start getting binding between the swashplate and the bottom of the main shaft. So far this mix, matches the stock mix pretty closely for normal mode.
