RE: engine dies during take off?
I think you should start with your needle valve, fixing the fuel leak, and also make sure the carb is on tight as well as the back plate is secure and there are no air leaks. I would also do as stated above by changing to a new glow plug. Make one adjustment at a time until the problem is fixed.
Good luck
Ryan
