RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 10-07-2005 | 02:51 PM
  #912
bdavison
Default RE: E-FLIGHT BLADE CP
So far this is what I got.
(Program this first, BEFORE you turn on the helicopter...otherwise, it's liable to go shooting through the roof or some other odd catastrophy)
Pick swashplate style "SR-3"
Reverse the aileron ch 1 and throttle ch 3
Goto the Swash AFR menu, and change the AIL to -50% (if its at +50%(default) the ailerons will be backwards)
There are 5 points on the Pitch Curve.
For Normal mode (eg no idle-up)
1. 0.00%
2. 13.5%
3. 15.0%
4. 20.5%
5. 37.0%
This pitch curve is pretty close to the one in the stock radio.
Dont go over 37.5% on the 5th point, or the swashplate will bind. You can set the middle ranges how ever you want them for personal preference.
This is as far as Ive gotten. You should be able to fly it on these settings, but bear in mind that the trims maybe out of wack, and the gyro proportional may not be set right. If you find that even with full right proportional on the gyro the heli still spins, try reducing either the pitch in the pitch curve, or the throttle in the throttle curve settings. Unlike the stock radio set-up, Ive found that the helicopter is capable of producing FAR more torque and thrust than the stock set-up, which is a good thing....I think. Im working on the gyro and revo mixes right now, and trying to figure out how to set up the idle-up's.
You may also have to take the servo arms off the servos and reset them to center.
I accept no responsibility if these dont work for you. Bear in mind these are like the beta version of the programming. So there may or may not be errors in there.
Once I have the final version with all the stuff programmed correctly, Ill post it up here.
