RCU Forums - View Single Post - MVVS 58 wont draw fuel
Old 10-07-2005 | 04:35 PM
DarZeelon's Avatar
DarZeelon
Default RE: MVVS 58 wont draw fuel
Barry,
All reed valve fed engines can run equally well backward... Like the Cox Bee and Texaco engines.
Adjust the position of the ignition pick-up to make your engine fire at TDC, during starting, then it will not happen.
For higher RPM, the VLACH ignition system will dial-in more advance.
Also, the quicker you flip-start, the less likely it is to happen.
