RCU Forums - View Single Post - The CEN on-road thread
Old 10-07-2005 | 06:19 PM
  #40
Scouser
Default RE: The CEN on-road thread
Reshimming means that you eliminate any play in the diff gears with washers. Normal usage results in wear in the diffs as the gears 'settle' and then eventually start to grind away the diff casing. When you reshim your diffs, you are basicallly resetting them and stopping any movement that would occur when the engine starts putting power through the drivetrain.
