RE: Ultra Stick 60 Challenges
More of the servo tray and rib repairs...
I chose not to sheet between the two ribs, mimmicking the opposite wing panel. Lazy or otherwise, this will work fine, is quick and easily accomplished.
Next challenge is the wing joiner fabrication and adjusting the wing bolt holes at the trailing edge. When I flipped the panel over, the angle became opposite. Since there is only balsa here, this should be easy enough. The 1/8" ply plate I will have to cut will reinforce this very nicely and I plan on inserting nylon bearer tubes as well.
This is what I accomplished in 2 hrs. my 1st evening working on my new "almost" ARF.
More to come....
Point Magu
