RE: Gas canister
Edgar, ya, that's the problem, there is 30 psi in the engine and the heat comes up the open ended propane line. The solenoid valve is what prevents that typically, so I put a check valve in place.
You can do a manual valve as well.
I found some engines don't need the check, some do, but better safe, put the check on all.
