RE: I need some ESC advice please!
Dude ... if the plane is 1.5 lbs then the 300B is not much performance, I mean my 400B on the 20 oz plane is already so so only. Also, you should try perhaps an APC 9x3.8 prop, will give you more thrust but not drawing much more amps.
