RE: Shorten the stroke. Good idea?
Shortening the rod would not shorten the engines stroke which I think is what you're driving at. A slight torque advantage can be gained by lengthening the rod and moving the wristpin higher and to the left in the piston but this is a lot of trouble for little gain, plus it increases the side thrust on the piston and increases wear.
