RE: Mounting Rimfire on Flatana
Programming.......What does this soft start feature do and how should I program it? I'm running the rimfire brushless with the BL-8 ESC on the stock 3 cell 640 MaH Li-Po. Also, what is the timing feature that you can program? I understand all of the rest. I have the motor hooked up all right, but when I throttle up, it does not start to move until it is about 1/3 stick, and when it does start to move, its really rough....is this something to do with the soft-start? Thanks a lot guys.
