RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 10-08-2005 | 11:31 AM
  #919
Jet Jaguar's Avatar
Jet Jaguar
Default RE: E-FLIGHT BLADE CP
Nimh batteries do not have the memory like a nicad does. and the best way to charge the nimh is to charge the battery just before use, or your voltage and mah will drop off depending on how long you leave them without use. you cannot leave them laying around charged like a lipo. and check your charger to make sure that you are charging with enough juice, ortherwise your charger may be timing out before it's charged.
