RCU Forums - View Single Post - Shorten the stroke. Good idea?
Old 10-08-2005 | 07:20 PM
jetski_waxhead
Default RE: Shorten the stroke. Good idea?
You are correct they are cam ground to help with heat expansion
thats why its hard to make a piston due to the fact you dont know how each piston will expand until you run it
and if you dont cam grind it then you will have larger clearance on the non thrust areas
where the gudgeon is
