Oops, I am back to 100% sure I do not have spark. Just before I switched out the plugs I took the ignition box apart to look for anything out of place (loose wires, broken solder joints ect) all seemed ok. I then switched out the plugs and it fired right up.
Today when I got to the field (same plugs ect that worked last night at the house nothing changed at all) all of a sudden no spark again, not even a sputter. I pulled the plugs they looked fine. Cleaned them, grounded them against the head and had a buddy spin the prop no spark at all. I even tried a spark tester, no spark. batteries all good switches all good. I am thinking there is a loose connection somewhere in the ignition that I must have moved when I too the ignition apart. Apparently its lost connection again. So looks like I will be sending the ignition back to BME or CH.[
