RE: lost flying field
Just my opinion, for what its worth. First, approach the widow and try to find out if you could pay her for use of the field. Second, even a 2nd hand garden tractor and roller should take care of most of the field. I use a water filled roller, it weighs about 700 lbs mostly full, (you want to drain it before winter), and try to roll every time I cut after it rains. It makes the field very flat for me. This is primarily the stuff I do at my field, which is reclaimed pasture. If you can get some friends together to help you, this should be a piece of cake, it only takes me about 25 min. , 2 or 3 times a week to keep my field cut. The main runway is about 220' x 50'. I cut at 2" so I can fly my 40 size planes with no difficulty. To me, it would be a shame to lose the field that you already have established. So, it needs to be cut by someone with a brush hog once to get the overgrowth down. Then follow up with two or three cuttings with a finish cut mower to get it back to the proper depth again.
