Old Style Equalizer--Setup Help
I have an older Equalizer. The kind with the little dip switches that you have to flip in order to program it.
The site only lists directions for the newer style Equalizers.
I want to use this to run dual elevator servos on a little 40 size plane. I need to reverse one servo and set neutral points and end points.
I've lost the directions for this unit--and I'm totally confused.[:-]
Need a little help.
