RCU Forums - View Single Post - *Modeltech Formula ARF 3D Competition 46-60*
Old 10-09-2005 | 07:15 PM
  #77
Zippi's Avatar
Zippi
My Feedback: (10)
Default RE: *Modeltech Formula ARF 3D Competition 46-60*
ORIGINAL: Cryhavoc
I thought that was your plane and it looks great! I have a couple of giant scale extra's, (Great Planes Extra 330L and a Wild Hare Extra Special) and they are designed to fly slower as well. Did you seal your gaps with clear monokote? Do you get much wing rocking in a Harrier?
Yes, I always seal the control surfaces with clear Monokote on the bottom. There is a little wing rock but not to bad. I think I set my CG at around 5" but once you fill the tank up it becomes nose heavy and requires a little up trim to keep it in level flight. You know what happens with a little up trim and trying to fly KE. You got it, tends to want to pull towards the canopy. That changes if you fly til your almost out of fuel and then the plane wants to climb all the time. I set my timer for 8 min. and that way it leaves about 1/4 of the fuel in the tank which works out ok. All in all, no big deal.
