RE: Excelleron 90 - discontinued?
My field will accept the small tires without problem so I plan on using them. The wheel pants will accept a much larger tire than those provided so that isn't a problem. The Icepoint gear is composite and there is a bit more area where the axle goes through so I think it wouldn't be a problem to use different longer axles and larger tires.
Gordie
