RE: H9 Aresti 40
Hi Stomper:
Thanks for the information. Yep, Stan's fuel seems to work well for sure. My aresti weighs about 5 3/4 lbs.
The CG is at 3 3/4" and is seems ok. The snap rolls are very snappy and seems to be on the verge of a tail heavy condition.
That's why I am sort of leary on adding or moving weight to the tail.
Perhaps it's just the way the plane flys.
Might add a deg or two of downtrust and retry inverted flight.
Again, while inverted I need a bunch of down elevator to keep level.
Where is your CG set at on your aresti? Also, do you think I can really get this CG back to 4"??
Glowfuel
