RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 10-10-2005 | 04:39 PM
  #936
stevennh
Default RE: E-FLIGHT BLADE CP
RogerC130,
I found real-flight 3d to be a big help in getting more stable on my Blade. I just used the 30 impala and found it to be very close to my Blade. I started with the 30 trainer, but it was a bit too sedate, the normal 30 model was much closer to the real thing. It is still a bit less touchy than the real thing, but it helps to build coordination anyway. I highly recommend starting with a sim...
bdavidson,
Thanks a TON for your setup instructions on the Blade. After a couple of crashes things were out of wack and after following your setup instructions my Blade is back to new!
Steve
