JetCat installation questions?
Hi Jets,
1.What max current ( how many amps ) should I expect in connection between battery pack and ECU (JetCatP120). I have difficult access to the ECU and I’m looking for the way of connecting charger without unplugging battery from ECU. What about installing heavy duty receiver switch with charging socket between battery and ECU.???
2. What is your opinion about disconnecting gas tank after turbine startup (before takeoff) ?
Regards
Marcin
