RE: Showtime
Mine did the same thing.. I forced a line up. after first day of flying there was so much force on the screws that the vibration from my motor popped the aluminum angles loose. when i glued it back i did the alignment myself by bolting it on while epoxy dried and problem was solved ( dont use too much epoxy or it will glue the canopy down to the fuse)
