RCU Forums - View Single Post - E-Flight Yak-54F Setup
Old 10-11-2005 | 10:05 AM
airboss82
Default RE: E-Flight Yak-54F Setup
Thanks for the input guys,
I went with the parallel setup because I had already built up the servo horns to the same size as the control surface horns. Plane flies great once I figured out the balance. Recommended balance point was tail heavy and quite exciting. I moved the battery 3/8 inch forward and it made a big difference. Very fun to fly now! Power is an e-flight 400, with the gearbox. Plenty of power.
Jerry
