RE: E-FLIGHT BLADE CP
Just wanted to give you guys a heads-up. Im still working on programming the 9CSuper for the blade. I cant figure out how to get the idle-ups set. I can program all the pitch curves and everything, but when I flip the switch, it just stays in normal mode.
Anyone out there know anything about this? Its probably something really simple, that Im missing. The manual is about useless.
I can post the programming up here once I get it all set, but the pitch curves are going to be different for each machine depending on where the servo arms are positioned at neutral, and where your linkages are set.
