RCU Forums - View Single Post - Nexstar Engine Help Needed
Old 10-11-2005 | 10:31 AM
richrd
Default RE: Nexstar Engine Help Needed
If the problem remains not tuneable. Go search the engine forum on this engine. I read where some had machining metal left in needle area where it has caused your problem as stated. They just tore it down an flushed, this is where they found fragments. It solved their problem of untune ablity, set rich go lean, thierfore brown caster. Note if fragments are causing lean your very lucky your using caster,last defense on over heating.
Just a thought Rich
