RE: Electronic brake valve ?
Tam: I use mixing for down elevator too that is only enabled when the switch gear is in the "down" position.. works great for me. It is good to know that more people around use the same solutions with success.
Carlos: I am using the springair valve. it is great and very easy to install, and the robart standard valve can be used too, just taping one air exit... a good thing about using this valves is that seems
that there is always one in the junk box!
Best regards, Enrique
