RCU Forums - View Single Post - No Power?
Thread: No Power?
Old 10-11-2005 | 12:23 PM
Commander_Drake
Default RE: No Power?
If the plane rolls forward when you idle the prop must be pulling OK. If the Engine revs up when you throttle up and the prop turns faster and you get less pull then it sounds like the prop is too flexible and the pitch is changing. That's my best guess. Or, when you throttle up the prop is slipping on the shaft and is actually spinning slower. Or, the laws of physics have been repealed in Idaho.
