ORIGINAL: drumbum
Mine did the same thing.. I forced a line up. after first day of flying there was so much force on the screws that the vibration from my motor popped the aluminum angles loose. when i glued it back i did the alignment myself by bolting it on while epoxy dried and problem was solved ( dont use too much epoxy or it will glue the canopy down to the fuse)
thanks for the info Lee
I thought about cutting the metal guides off and realigning them myself but I ran into a quandry when i tried to figure out the best glue to put them back together. JB Weld?
I can force 2 screws to lineup but thats it and I know I am going to have the vibration issue as well. *sigh....*
matt
