Need some help on looping my plane, it just corkscrews
Check that both sides of the elevator go up the same amount when you pull back on the stick. If they are on seperate pushrods, one could be going up more than the other. Also sight forward from the back end and make sure that the tail is not scewed from the wing. Look forward and make sure that the tail is straight with the wing in reguards to twist is maybe another way to say it.
