GTR, you dont want to do a inverted flatspin landing, could crack your canopy[&:]
is your ucd needing constant right rudder input, if so you might need to go with a degree or two of right thrust, 1 deg right and 1deg up helped mine with the saito 100 but yours might be different, the 100 made it pull a lot to the left so i needed a little right.
Landing in your yard-------- what a plane!!!!!!!!!! HUH!!!!!
