I will finish this thread...I will finish this thread.....
Ive got the remaining pictures taken, and hopefully will get everything up here soon.
The next section will be the performance section. Ive got some tips that will help you guys get max performance out of the Blade.
Including a easy modification for the tail rotor that adds a "prop saver" to keep you from breaking tail blades.
A more in-depth look at balancing blades, and making sure that the rotor head is balanced and trimmed PERFECTLY.
Getting the heli ready for inverted flight.
How to fix those skids so that they wont break. The skids are WAY to fragile, there is an easy modification you can do that will keep you from snapping them.
Im hoping also to get some video up of the blade taking it to the max including some inverted stuff.
