RCU Forums - View Single Post - ZDZ 80 single issues
Old 11-02-2002 | 04:21 AM
AtomHeartMother's Avatar
AtomHeartMother
Default ZDZ 80 single issues
Hmmm...I wonder if it's flooding out.
You might be getting some weird suction effect around your carb venturi once you're in the air, causing a super rich condition at idle. I'd say a velocity stack would be worth a try, but that motor has a rear mounted carb doesn't it ?
Usually if it runs great on the ground and acts goofy in the air, it's an air/fuel metering problem revolving around too little or too much air pressure around the carb venturi.
