RCU Forums - View Single Post - Timing of motors
Old 10-14-2005 | 04:39 AM
wvr's Avatar
wvr
Default Timing of motors
Is there somebody who can explain the influence of the timing of the controller in relation to the behaviour of the motor.
The reason why I ask is that I received from Hacker to set the controller to 30degrees of timimg to run a Plettenberg 30-10.
I most post, I see 18 degrees, and it the spreadsheet of an other post, I see 5 and 10 degrees.
I read somewhere that there is also a relation with the number of poles the motor has.
In the 'brushed days' you could retime to get higher RPM with higher current.
Winfried
