600R No Start
Tried to light my 600R for the first time ... no joy. All indications on the are TCU normal but I was not seeing any indication of gas flow to/thru the solenoid valve. If I disconnect/remove the valve, during a start-up sequence, what turn-on voltage should I expect to see at the end of the connector coming from the ECU?
Otherwise, I'm gonna scrounge thru my stuff and hook up my trusty Ram propane bottle thru a 1-way valve on the input gas line. I'm pretty sure I'll get a non issue start up to ramp with that setup but meanwhile ...
Thanks for any help.
Mike
