super tiger 3250 help
I stand by what I said about what prop for what engine. I will give you this analogy. A guy can tow a one ton boat with his VW beatle, how can he do that? Easy he live on the top of a hill and its all down hill, someone else drags it up for him. If your plane weighs 10 or 12 lbs and the tigre is out in the open on a firewall the engine can run very rich and still fly the plane without over heating. If all you had to do is use bigger props then and engine was designed for the company's that make engines would simply cut their line of engine down as they wouln't need to produce bigger ones.
Please don't respond to this unless your name is Baxter
