RCU Forums - View Single Post - The new Lanier Edge 87"
Old 10-15-2005 | 06:51 PM
  #77
BoneDoc's Avatar
BoneDoc
Default RE: The new Lanier Edge 87"
Joe,
What I meant by 4 oz is that the servo is 2 Oz, and the distance of moving it to the pull-pull would be 1/3 from the CG as previously, so that would be equivalent to a 4 oz saving of nose weight needed. The servo cutout is already done for you, so if you go with pull pull, then you'd have to buy a black covering to patch it up (no biggie).
As promised, here are some build pics. There really aren't that many need for build pics since it's more of an assembly. All the robart hinge points are drilled right on for a perfect fit, and they're all centered. One difficulty I have was in drilling the control horn holes (having a drill press might have helped).
Sorry about the mess
