RCU Forums - View Single Post - Suggestions for E-Flite Tensor 4D setup?
Old 10-16-2005 | 05:59 PM
Devin McGrath
Default RE: Suggestions for E-Flite Tensor 4D setup?
I stripped 2 gws pico servos on the ailerons of my Tensor 4D and an hs 55 is what I ended up using and if I was doing it all over again I would use an hs 56. To stop mine from breaking in half I used fishing line bracing to stop the tail twist and to make it stronger. if you would like some picture I can take some.
