RCU Forums - View Single Post - art tech cessna problem!!
Old 10-17-2005 | 12:56 AM
stockdaddy
Default RE: art tech cessna problem!!
This mutiplex motor is a good fit for the Cessna:
http://www2.towerhobbies.com/cgi-bin...?&I=LXEXU1&P=0
I had bent shaft so i needed replacement. I got mutiplex because I had good luck with this brand in the easystar plane i have. Just be sure you get similar weight as the stock motor so you don't mess up the CG.
